Extracting embedded features from a parent feature
tcooper
I thought I was being neat in embedding a couple of datum's at angles within a hole feature, so that one feature shows up in the model tree and when you go to edit the hole, you get all the dimensions to modify the hole including the angle the hole is drilled at. Only now when I want to include that angle in an .asm relation so the mating hole always has the same angle, the angle of the embedded datum does not come up when picking the hole. I tried using the part feature dimension symbol of the angle in the asm relation, but it says it's an unknown symbol. Other than writing a parameter to carry the angle is there a work around?
Tim P. Cooper
LM IS&GS-CIVIL, Houston
ITL Facility and Mockups Design
LM2 / Cube 228L
Physical Address: Correspondence:
2400 NASA Pkwy LM2, 304B
Houston, TX 77058 P.O. Box 58487
(281) 333-6735 Houston, TX 77258-8784
(281) 333-6300 (F)
0 REPLIES 0
