SUMMARY: Discovering holes in WF5...
DarrinHiebert
Thanks to everyone that responded!
These are my comments about the responses that I got, and then I'll list
the responses below.
One suggestion was to find all of the one sided edges with Find. The Find
command does actually appear to do that, but it does not appear to work if
the object is imported. When I would select the import, I wouldn't get
anything, because Pro sees it as one entity is my guess.
The pre-Wildfire schema definitely helps, and this is one of them rare
instances where you're almost better in wireframe than you are in any
other mode.
But the best solution is the IDD, and then Geom Checks. I did remember
seeing this at a user group of conference, but had forgotten where it was.
It's buried fairly deep.
And, with all of that being said, I had to sadly give up on this model. I
don't really think that there's anyway that I'm ever going to actually
"repair" it to the point that I need to get it. I have approximately 400
things that need to be fixed on this model, and I don't need it fixed that
bad. It's just too much work what I want to get out of it.
Thanks again for all the help!!!
RESPONSES:
I have chosen to stay at wf2....when you find a good hammer, no need to
upgrade it, until they change nails.
With that said, I have no idea where they hid the functionality you
seek...no matter it rarely worked.
Try to match the accuracy. (you can find it in a iges file)
geometry checks may have some clues.
From past experiences...looks at corner rounds.
Try a copy quilt....it will most likely fail but may show you where the
problem is hiding.
Another thing that has worked for me in the past...fix it the best you
can...once your stumped export it out as a step and import it back in. I
have received many free fixes. Pro/Engineer is your friend.
Visually, the pre-wildfire color schemes are great for visually hunting
for "holes" in quilts.
If you use pre-wildfire colors such that stitched edges are purple and
open edges are yellow, I can typically hunt down visullay small open ends.
some times it takes awhile...
I thought that typically, when attempting a solidify a quilt that is not
100% bounded, an "arrow" would appear on the surface body near the area
that is open??
Darrin, while in IDD, select Info --> Geometry Checks. Once there select
Edit --> IDD Settings and choose the checkboxes of areas you wish to
highlight. You will then get a listing in the Import Feature that you can
expand and select to show in the graphics screen. There is an IDD
tutorial in the Help Center that has directions and models to provide some
familiarity with IDD. Here is a link to a video from a tips/tricks
session on using IDD:
0 REPLIES 0
