Extruding a 3D Circular pin
KC_10566988
3-Newcomer
I am trying to extrude a .1250 radius circle and it keeps turning into a hexagon. How can I fix this ?
My best guess is that edge display quality is set to low, affecting how accurately the model is displayed (it is still round).
Go to File > Options, select Enitiy Display and change Edge display quality to a higher level.  This may affect the performance of the program, requiring more computing power to render the model.
7 REPLIES 7
tbraxton
22-Sapphire I
(To:KC_10566988)
Not enough information provided. Post models or explain in detail what you are having an issue with.
Involute Development, LLC
Consulting Engineers
That worked, thank you so much!
tbraxton
22-Sapphire I
(To:kdirth)
Creo 7.09 with edge quality set to low (the lowest setting). A circle is not rendered as a hexagon.  I find it hard to believe that Creo would render a circle as a hexagon under any setting for edge quality. If someone can reproduce this "problem" please post the data for review.
kdirth
(To:tbraxton)
7.0.10  Small diameter / low display quality / low accuracy.
tbraxton
22-Sapphire I
(To:kdirth)
Indeed, I can get a 4-sided representation of a circle (in a model with absolute accuracy set). Fortunately, I have never had to work on hardware that would require the low edge quality setting, but this is nonetheless surprising. The only place I had seen this happen previously was with VRML files used in Pro/E.
I can get the 4-sided render by making a high aspect ratio cylinder.
tbraxton
22-Sapphire I
(To:kdirth)
Props for guessing a solution based on that initial post!
