FAMILY TABLE IN MIRROR PART
gvora
Does anybody know how to include the family table in mirroring the par?
Thanks.
Gautam Vora.
3 REPLIES 3
BrianMartin
(To:gvora)
Hi Gautam...
Can you explain this question more? If you want to simply include the mirror feature in the table, that can be done easily. But I don't think I'm understanding your question correctly. Do you have a screenshot to share or some additional information?
Thanks!
-Brian
kerzen
(To:gvora)
Hi Gautam.
It is not strait solution but I did managed to do it.
1.) Create mirrored part ..FILE...MIRROR PART as MIRROR GEOMETRY WITH FEATURES
2.) EXPORT family table as PRO/TABLE file
3.) in mirrored part create at least one instance and then import that table
4.) change the name of instances to avoid duplicate names
5.) Note that family tables are not connected...if you will change any value in original file there will be no change in mirrored part instances geometry but you can edit it by your self or just repeat steps from exporting family table to importing it into mirrored parts family table.Apparently names of dimensions are the same that's why importing of the family table works.
I hope I was clear enough and that I vas helpful
Best Regards
Klemen
mtomala
3-Newcomer
(To:gvora)
Hi, someone try this?
I have problems with this, when I try import instances I have issue:
"Invalid name or format found in instance..."
Maybe I don't understand this well? Step no.2 EXPORT family table but where was she create?
M.
