I would like to know if there is a way to avoid Creo splitting a surface into two surfaces (see picture)
In this case, I created the outer geometry and subtracted the material in the middle.
Hi tbraxton,
I've imported a table of datum points to create a curve (in green), and used the curve to cut the geometry:
I mean, the same thing happens when I cut it with a circle:
why does Creo do this?
Cylinders in Creo have always been split in two.
Though I am not certain of the reasoning, I sure there is a logic answer from a programming standpoint.
The reason was....they got lazy. It's been a complete PITA the whole time I've used it, there's no reason for it ESPECIALLY since NO OTHER CAD system I know of does it. It should have been fixed LONG ago.
Sorry OP, you're hosed.
Circles/cylinders are always split in Creo. Having said that your cut is not a circle. Can you post the table of points? Without actual data to query it is hard to say why it is split.
