Facing lag while using Creo 6, Not able to select Datum plane for creating a sketch
Vue412
8-Gravel
I have installed Creo 6 in my system, but facing a lagging while doing part modeling not able to select the datum plane for creating a sketch, Earlier I was using Creo 5 and I have not faced such an issue with it. Please help
MartinHanak
(To:Vue412)
put graphics  win32_gdi option into config.pro file to eliminate graphic card driver problem.
Martin Hanák
3 REPLIES 3
MartinHanak
(To:Vue412)
Martin Hanák
Now it is working, Thank you for your help
MartinHanak
(To:Vue412)
I hope you know that graphics  win32_gdi option is for testing purposes, only.
Final solution >>> remove the option from config.pro and install other graphic card drivers. You can start with current version.
Martin Hanák
