Hi all,
(Creo Elements/Pro 5.0 M70 on XP64)
I have a pretty complicated assembly and I want to create some kind of assembly processes for specific
areas. I create a Simplified rep which I want to save it as an external assembly file. Then i get this message:
"Please confirm excluding missing components". If I click "yes" I get the assembly open in a new Pro/E
window, with some components missing.
I have tried to create a external simplified rep as it is mentioned in the help file
without any luck.
The funny is that when I select to open the assembly (step 5) from which I want to create the
simplified rep, I don't get the assembly open in a new window. Instead I get an empty assembly file.
Then I create the rep in the main assembly, followed the same steps, I choose in "step 5" to open a rep, I select the rep
and the I get the same empty assembly file.
Is this a bug or something?
Thank you!!!
| 1. | Click File ▶ New. The New dialog box opens. |
| 2. | Click Assembly and select Ext. Simp. Rep from the Sub-type list. |
| 3. | To use a different template clear the Use default template check box. |
| 4. | Enter a name for the external simplified representation or accept the default and click OK.
Note
When you clear the Use default template check box the New File Options dialog box opens. Select a template and click OK. The Open dialog box opens. |
| 5. | Select a reference assembly and click one of the following:
Note
The Enable On-Demand Updating option is available for a representation type other than the Master representation. |
