Hello all,
When i open a drawing file and then open the assembly from the drawing, the model tree looks good, but when i open the assembly alone the parts are having failed features and constraint errors are highlighted. Can anyone guide me plz
Thank you.
Best Regards,
Nanditha
First try regenerating the model that you open from the drawing and see if it fails even though it looks good.
Thanks, Dale
maybe your drawing contains several drawing models and these models are referenced by the assembly. This means the drawing opens some components used in the assembly before it opens the assembly.
Martin Hanak
