How can I use parameters of Modeling fuction? I don't know which ones ? what's default parameters.I just use &ptc_material_name that follow model. It's default parameters, I don't know other default parameters that follow model. Anyone can tell me. Thank you very much
When you have your default template open, you can find your default parameter set by selecting the "Tools" tab then in the Model Intent section of the ribbon, you will find and select "Parameters". A separate window will appear with all the definitions.
Should you open an active object (other than default) and follow above instructions, it will show the default parameter set plus any other parameters defined for this object.
A previous discussion on a similar topic can be found here:
How to use these parameters in the drawing:
http://www.cad-resources.com/System_Parameters_for_Drawings.pdf
Ron
Thank you for your reply
But I need the fuction for this picture
This topic fits my needs,But I needs all Parameters that follow model.
Thak you very much
empty model contains no parameters. User has to define all requested parameters inside the model. There are no system parameters.
Martin Hanak
