I have a family table with the instances.. I want to show the views of all the instances with the parametric ballooning, in a single drawing sheet. can anybody give me solution.
Thank you,
Prakash
I suppose you can't do ballooning to for Family table.
You can add Family table in drawing using reapeat region - add- 2D after making table. (details available in help file - check repeat region in detail drawing)
and you can add model in drawing of all instances by right click on drawing sheet- property - drawing model - add model- give that model & select the req. instance.
Hi Ganesh,
How I would be able to do ballooning in a drawing for which multiple instances are there.
Regarding drawing of other instances, I am not able to add into same drawing sheet. Could you please explain it in more detail please?
Regards
Ketan
