Fatal Error while accessing an Assembly model
PN_10213343
I am using Creo Parametric Release 6.0 and Datecode6.0.3.0
an error is observed while trying to open an assembly model. and this is happening for only one model.
Fatal error encountered. A traceback log is written to
BenLoosli
(To:PN_10213343)
If it is only one model, then most likely it is something in the assembly structure.
If it is multiple sub-assemblies, be sure each of them can open.
A traceback can only be resolved by PTC tech support and they will need to have you upload the file to them with all components.
