Fatal error encountered while using " Perform symmetry analysis in Save a Mirror Assembly"
suraj_bhorge
3-Newcomer
Save a Mirror Assembly works fine when "Perform symmetry analysis" is unchecked.
When I use "Perform symmetry analysis", it opens up a window containing a list of components that are going to reuse and new mirrored components.
If I click on OK of 'Mirror Assembly Components' window, It gives "Fatal error encountered. A traceback is written to 'working directory'. Please send it to Technical Support."
traceback.log file is attached.
Anybody in the house, who can help me with this?
2 REPLIES 2
please report the problem to PTC Support. They can analyze traceback.log file.
Martin Hanák
I did a search for exit when using Perform Symmetry Analysis and found an existing case, which was resolved by setting the config option shade_quality to 20 or 30.
Please give this a try and see if it helps.
