What-up!
I have something set in config.pro where sketch features stop snapping to references.
What could be set to cause this problem? Bug?
Creo 2.0
The config.pro file is attached.
Load the config.pro in a dummy folder and set this dummy folder as a start directory in the creo shortcut.
Start Creo and create a new part and select any datum for a sketch.
Try attaching a line or rectangle to the two reference lines. I get no snapping joy when I do this.
Antonius,
remove sketcher_rel_accuracy 0.00001 option from you config.pro.
Martin Hanak
Antonius,
Martin Hanak
Interesting. I would have never guessed but that worked. Is it a bug?
Is it a bug or not ? That is the question ...
If you have a courage you can ask PTC support
Martin Hanak
Submitted as Case #10885254
