Filter Skeletons out of BOM
dgschaefer
WF3
My BOMs are showing the skeleton parts and I'd like to take them out.
How does one do this?
Doug Schaefer
LinkedIn
dbowles
(To:dgschaefer)
Table/Repeat Region/Filters/By Item/Exclude/select row in table/Ok Done
Douglas K. Bowles
Advanced Systems Harn/Des
520-746-2019 Office
520-490-9395 Cell
PRIVACY ACT NOTICE: This communication may contain privileged or other
Official information. If you are not the intended recipient or believe
that you have received this communication in error, please reply to the
sender indicating that fact and delete the copy you received. It is a
violation of Federal Law to print, copy, retransmit, disseminate, or
otherwise use this information without prior authorization.
A couple of folks suggested manually filtering by item. This works, but
I was looking for an automated way, in the unlikely event that a
skeleton is added, it will automatically get filtered. A table can be
saved with this filter (I think) and it will then filter skeletons
whenever it is applied to a drawing.
I found it at MCADCentral [1] via Google:
Go to Table -> Repeat Region -> Filters -> [select your table] -> By
Rule -> Add
Then paste the line in the entry field and hit enter:
&asm.mbr.type != SKELETON*
Finally, click 'Update Tables' to refresh the table display.
[1] -
http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=38610&PN=32&ge
Tel +1 614 890 0202
Fax
Design Central designet
6464 Presidential Gateway
Columbus, Ohio 43231
USA
Confidentiality Notice
This is a transmission from Design Central Inc, Columbus, Ohio which may
be privileged and confidential, and thus is protected from disclosure.
This message is NOT intended for transmission to, or receipt by, anyone
other than the named addressee (or a person authorized to receive and
deliver it to the named addressee). If the reader of this message is not
the intended recipient, or an employee or agent responsible for
delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution or copying of this
communication is strictly prohibited. If you have received this e-mail
message in error, kindly accept our apology and please delete it from
your system without copying or forwarding it, and notify the sender of
the error by reply e-mail or by calling  (collect).
LinkedIn
