Find dimension and it's symbolic name in Assembly mode?
  • December 8, 2012
  • 1353 views
I'm trying to look for the symbolic name of this distance.
I need to find the symbolic name because I will be using it in Pro/Program.
As you can see, I used an extended axis to find the distance between those two points. If this method of finding out the dimension is wrong, then please inform me.
Otherwise, how do I find the symbolic name for that distance in Assembly mode?
I've tried using the sketch mode, but that did not go well with Pro/Program as nothing changed when I inserted a specific value.
And the book I am following refers to a "skeleton curve", any ideas?
Any help is appreciated!
Thank you!
Hello Kevin,
It is difficult to say without seeing the assembly myself but if the book refers to a "skeleton curve" I imagine that
the position of those holes is driven by a skeleton further up the model tree.
A "skeleton" is essentially a model built up of sketches and datums to act as a framework on which you can build your parts/assemblies.
If you can find the skeleton model in the model tree (the icon, or 'glyph' next to it should look like a transparent cube) you should be able to select the sketch feature, right-click and edit to show all the dimenions, then go to the command search and type switch dimenions to see the symbolic name of the dimenions.
I know this may be of no help but best of luck.
Cheers
