I have a medium-sized assmbly (about 80 different components) and I am trying to find its mass and CG. I assigned all the materials but I must have made a mistake in one or more parts because it's wildly overweight. I can figure out how to generate a list of the parts showing their mass individually - I'm sure whatever is wrong would jump right off the screen at that point.
I also tried adding a column to the repeat region on the assembly drawing that would show the mass, but the closest parameter I can find just shows the density and it's not really helpful. I'm sure I've assigned an in-lbm value to a kg-mm-sec part somewhere though.
Any thoughts?
TIA
