Flex_pipe setting in pro/piping MCAT file
JasonWu
Now I only use non_spec_driven model for drawing flexible pipe in pro/piping. but in Pro/e 5 help file I saw it may use spec_driven model too and need set "flex_pipe" in MCAT file, who know it how to set? Now I only draw straight pipe in spec_driven model.
JimBarrettSmith
(To:JasonWu)
Using the attached files
In piping_data\master_catalog\pipethk add thk_flex.ptd
In piping_data\master_catalog\pipeod add od_flex.ptd
In piping_data\master_catalog\pipe add pipe_flex.ptd
In piping_data\master_catalog\piping_units_system_dic_file.ptd add entries for the flex pipe (as per attached piping_units_system_dic_file.ptd)
In piping_data\master_catalog\piping_mcat_dir.ptd add entry for the flex pipe (as per attached piping_mcat_dir.ptd)
In piping_data\master_catalog\piping_material.ptd add entry for the flex pipe (as per attached piping_material.ptd)
Once you have added the files enter spec piping and when you go to define your new specification you will be able to select the flexible pipeline. once you have defined your new specification you will be able to select it for routing.
6 REPLIES 6
JimBarrettSmith
(To:JasonWu)
Hello Jim,
I have copy these file to corresponding folders and I have setted up project data file(flex_asfile.ptd and piping_spec_dir.ptd), but system message is as following, do piping_manufacute_dir.ptd file need been setted up too?
otherwise, I think in spec driven module it maybe should have option window for flexible or straight that like the similar window in non_spec_driven module.,so I may choose pipe is flexible or straight in spec driven module. Can it achieve?
JimBarrettSmith
(To:JasonWu)
Jason
Apologies I forgot about the attached file. Add the RB line in the attached file to your piping_manfuacture_dir.ptd
To set the line shape in spec you should select Pipe Envrnmt \ Line Shape \ Straight Done
Jim
Hi Jim,
I have successed to model the hose that you set up the size, it may choose flexible or straight. I will continue set up my hydraulics fittings library and finish your file. please continue to help me if any questions. thanks again.
Hello Jim,
I see the parameters: "SIZE_CODE" and "COMBINED_SIZE_CODE" in od_steel.ptd and combined_size_code.ptd, what is their purpose? May I be the blank cells for these parameters?
visu
(To:JasonWu)
i am new to pro-e piping
May i kno whow to create SPEC DB? and create?
Thank you
