Flexible Component
LJ_10823216
Flexible Component
I am using Creo Parametric Release 9.0 and Datecode9.0.0.0
In my main assembly I am trying to assemble jumpers assembly as a flexible component. Earthing jumpers are two sub-components, so I am trying to assemble in different lengths and directions. I am able to constrain distance and it works fine, but direction of the subcomponents will be different, I cannot rotate subcomponents, only earthing jumper rotates. For example, in the first position Earthing jumpers have two subcomponents, component 1 should have an angle offset of 35 degrees and component 2 should have an angle off set of 65 degrees. In the second position, in the same way, component 1 of Earthing jumpers should have an angle off set of 45 degrees and component 2 should have an angle off set of 25 degrees. Let me know what is the best way to keep them consistent.
3 REPLIES 3
StephenW
(To:LJ_10823216)
If you include an image of what you have and what you need to accomplish, maybe that will help get a response.
First, I would suggest predefining the flexibility in the subassembly. (File/Prepare/Model Properties and select change for flexible in the tools section.)
Second, to get the angle of a subcomponent to flex, you need to select the component using query select or selecting it in the model tree.
Try use "PTC_CONSTRAINT_SET" refer to https://www.ptc.com/en/support/article/CS46389
