Flexible components in subassemblies
Helena
I have a question regarding a flexible component in a subassembly.
A component is mounted in an assembly as an flexible component. Now I need to show this component in a different position in a top assembly (three level higher). I tried to make the assemblies in the differnent level flexiblel, but I only got error messages trying. (Varied item (d19 0.000000 -> -60.00000 9100762122002 (Not applied)) is overridden.)
Is there anyone out there who can give me a suggestion on how to do this?
2 REPLIES 2
Helena
(To:Helena)
Sorry, I forgot to add that we use Creo elements/pro 5.0.
SylvainA.
(To:Helena)
You can make a family table of your subassembly and modify the varied dimension of your component in each instance of the subassembly.
Then, in your top assembly, you can replace the original subassembly with one of its instances.
