The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
For me, it's a bit complicated things.
bduncan
Hi all
Here is a drawing which called feeding body.How to create it into 3D model?
Be grateful!
I think you would be better off using 2 revolved conical surfaces rather than a boundary blend as illustrated by a comparison of your curvature plot and the following:
It appears that you have created a blend from the angled edges at the large end to the coplanar edges at the small end; this is going to produce a slight departure from truly conical surfaces as illustrated by your shaded plot. This is critical for your design because you have a conical auger rotating inside. Furthermore, it's likely that you would have trouble converting what you have into an acceptably simple model for rolling the sheet metal into cones.
8 REPLIES 8
This forum really isn't the place for us to do full designs for each other. However, looking quickly at your geometry, maybe a couple of snapshots will help you get started.
Create Axis A_1 through DTM1 & DTM2, DTM4 through A_1 at an angle to DTM1, A_2 through DTM4 & DTM3, revolved surface on DTM4, mirror about DTM2, and Merge the two surfaces.
Merge, then Thicken.
Would you like share the modle with me ?
Here you go.
P.S. You better double-check the cone angle dimension; it was garbled in my view of the drawing (I used 10.5).
Thanks,The picture on the display is the way I designed. Does this curvature can be acceptable?
Thank a lot .Bothers my problem is solved.
