Currently we have a format/template where the Table/Repeat Region is added to the drawing after the model is applied.
I'm testing making the Table/Repeat Region part of the format/template and ran into a relations error issue.
Background:
Our models have a parameter BOM_QTY_TYPE.
Currently we add the Table after the drawing is created using a drawing template.
The current table relations look like this:/* Relations to set bom qty per BOM_QTY_TYPE model parameter if ASM_MBR_BOM_QTY_TYPE == "AR" | ASM_MBR_BOM_QTY_TYPE == "NA"\ | ASM_MBR_BOM_QTY_TYPE == "ALT" | ASM_MBR_BOM_QTY_TYPE == "PM"\ | ASM_MBR_BOM_QTY_TYPE == "EM" | ASM_MBR_BOM_QTY_TYPE == "ARS" Qty=ASM_MBR_BOM_QTY_TYPE ELSE/*Sample relations for faking BOM Quantitiesif asm_mbr_description=="123-4567-890"qty="xx"elseif asm_mbr_part_number=="12345-67"qty="xx"else Qty=rpt_qty ENDIFendifendifIF the model parameter for BOM_QTY_TYPE is anything other than the six values listed in the relations the qty shown is the number of items in the assembly.
