Format Title Block Text
pgress
Since this list was so helpful for me in previous cases I figure I'd ask
for another stumper, at least for me.
When I create a drawing format, I added entries for sheet numbers to be
automatically created as I add sheets. This is good and exactly what I
want. But I'm getting tired of adding drawing titles, revisions and
part numbers on all other sheets. I don't see how to create the text
just once and have it carried through all other sheets, say similar to
spreadsheets. Is there an easy way?
Paul
1 REPLY 1
Hi Paul,
Yes.
The method I used is to call up parameters in your title block for all the
things that you mentioed. In case you are not familiar with calling up
parameters in a drawing then the format is ¶metername. If you do not
have the parameters defined in you model or assembly then when you commence
making a drawing it asks for each value. However I don't like that method
so instead we have a our start parts with all the parameters specified with
a default value. This means a new drawing are auto-populated with these
defaults. We then change the parameter values in the part or assembly and
these update the drawing. Now for the best bit; each new sheet is also
auto-populated with the same parameters.
Works like magic Smiley Happy
Hope this helps.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
> want. But I'm getting tired of adding drawing titles, revisions and part
> numbers on all other sheets. I don't see how to create the text just once
> and have it carried through all other sheets, say similar to spreadsheets.
> Paul
