hi everybody...
i have recieved some proe assembly files from our customer which is arranged hapazard manner in different folders.
Now i have shifted all the components in one single folder in order to open the assembly sucessfully.
now i want to know whether i can save the assembly into a fresh folder which includes all the parts associad with the assembly.
kindly help.
regards
arun mathew
If you are trying to save within ProE try using File>Backup. This should allow you to specify a new folder and will create new files associated with the assembly.
