Frozen references mystery
Bfy-Taco
2-Explorer
Hello All,
I have a large 3D scan that I am working with, and trying to build a basic skeleton structure around it. So creating a few sketches and datum features (planes & axis). Now here is the issue. If I redefine any of those features, any reference to the scan has a "frozen reference" note in front of the reference/feature name (see attached image). Been using Creo (Pro/E) for over 30 years and I have never seen anything like this. If the reference was missing, I would get it. But it's not missing. What gives? Not sure how to fix this.
BTW, using Creo 10
TIA,
Victor
3 REPLIES 3
tbraxton
(To:Bfy-Taco)
Based on your screenshot, it looks like you are referencing facet geometry from the scan data.
You can use some of the facet entities created in Facet Modeling in downstream operations and applications of Creo Parametric. For example, you can use facet faces, facet edges, and facet vertices as placement references for datum planes, datum axes, and datum points.
 I suspect it is related to the fact that you are using facet geometry as parents to Creo features. Geometry that is defined using facet geometry does not update when you edit or move the facet geometry, like it would update when you use regular geometry references.
If you use the global reference viewer, what does the dependency map look like for these frozen refs?
Involute Development, LLC
Consulting Engineers
Bfy-Taco
2-Explorer
(To:tbraxton)
Thanks for the response.
The geometry is being created in the same model as the mesh (scan import geometry). It's not a living mesh (changing with each regen) It's no different than an imported STEP file.  But yes, I am referencing facet vertices.  Nothing is moving or changing within the imported geometry.  It's dumb geometry.
tbraxton
(To:Bfy-Taco)
What does the GRV dependency map show when checking the frozen refs? Facet geometry is not the same as STEP import geometry.
