I have a print that is dual dimensioned. (mm primary -inch secondary w/ the display set to secondary[primary])
The problem I'm having is in the geomentric tolerances. The value is shown as .0 [0.02].
Anybody know how to change the decimal places of the secondary to show as .001 [0.02]?
Steve Shannon
Tooling Engineer
matic
300 East 48th St.
Holland, MI 49423
phone (616) 820-2427
fax(616) 820-2488
Should be a combo solution in your drawing setup file.
Dual_digits_diff
lead_trail_zeros
Your feature control frame values will follow the dim decimal places and zeros configuration.
Oh....make sure your lead_trail_zeros_scope is set to "all". It should be as it is the default value. Check it regardless.
In Reply to Dean Long:
Dual_digits_diff
lead_trail_zeros
