Generative Design - Optimization working on Multi-Bodies
ErikClacey
I'm running Creo 9 and there is an option to merge bodies. Is that not possible in Creo 8?
(Note from the Moderator: this question was a comment, moved from this Creo idea)
1 REPLY 1
In Creo 8, you should be able to merge bodies by using the Boolean Operations feature, which includes Merge, Subtract, and Intersect operations between different bodies in a part. Same in 9 just improved UX.
