Hi Guys,
Can we use the model check to detect the ghost reference and break it, is it possible?
Aj
Not sure about model check but here are a few help resources you've probably already found:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Ghost-of-parts-past/m-p/29141
(Look for Marc's reply)
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-cleanup-remove-ghost-objects/m-p/489431
