Green box in drawing in place of the actual view of the model.
Milkman
3-Newcomer
Has anyone had this show up in a drawing? I don't know what happened to my detailed view and I can't even select the green box to do anything with it.
10 REPLIES 10
psobejko
(To:Milkman)
It looks like you erased the view called "MAIN_VIEW" - you can confirm this if in the Drawing Tree, the view name has an icon that is grayed-out.
If that's the case, you can resume it right-clicking its entry the Drawing Tree list and selecting "Resume View".
Or, switch to the Layout tab, then in the "Display" section, select "Resume View".
Milkman
3-Newcomer
(To:psobejko)
"Resume View" is not an option. Delete is my only option from here.
Mahesh_Sharma
22-Sapphire I
(To:Milkman)
As Paul mentioned view which is in green (Main_view) is an erased view. To display this view, you need to resume the view using Layout Tab > Select View > Resume View or simply select the view name in drawing tree > RMB > Resume view.
Erase view functionality is basically to increase the performance when working with large drawings.
Your view might be missing a reference. Review the view properties and see if something is missing.
This is an unusual case since resume doesn't work.
I can not view properties as I can not select the view.
psobejko
(To:Milkman)
Greg, does this ghost view show up in your drawing tree? If so, right-clicking on the listing there only shows up "Delete view" option?
This is strange. I tried to make this failure appear by making a detailed drawing and then deleting the component that the view is referencing, but all you get is a warning.
I also tried to make a drawing with views based on several models. If I deleted one of the models and tried to retrieve this drawing, it would not open at all...
gkoch
(To:Milkman)
Greg,
since everybody expects the option "Resume View" to be available and it is not, you probably should consider opening a case with technical Support - I hope you can provide your drawing for investigation?
BTW: Is this really about Creo Visualization or is is standard Creo Parametric in drawing view? Maybe the model associated with the drawing view is missing?
Gunter
Milkman
3-Newcomer
(To:gkoch)
It is a standard Creo Parametric model but a layout controlled program is being used. We are thinking the problem must have to do with that.
GabrielZaha
(To:Milkman)
In this situation you may want to take a look at "Drawing Program" under the Tools tab:
"Define states" menu allow you to select which view to show or hide for a given state.
"Edit Program" is where you set the conditions to enable or disable the states previously defined.
If you want to edit the program I suggest to use the "File Edit" option. This will open the program in the text editor (like notepad).
