Grouping a Box around Text in a drawing.
dbower1
Should be simple...
I have a note with a leader. I draw a box around the text. Create a draft group of the Box, Text (including the leader.) Everything moves together as it should.
Make a change to the model... the text jumps outside of the box. Have to explode the group, move everything back, re-group. There's gotta be a better way!
Thanks!
David
3 REPLIES 3
wrsamuels
(To:dbower1)
Use @[ in front of your text to start boxed text, use @] to end the box.
There are a bunch of commands like that....
Feel free to contact me with any questions
Bill Samuels
603-885-2506
You could create it as a symbol.
I was going to recommend @[<text>@] but you said you included the leader. This just does the text. I would recommend a symbol.
Michael Wimberly
Engineering Applications Support Specialist III
Global Tactical Systems
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 833-3565 Mobile
(513) 881-5087 Fax
-<">mailto:->
P Before printing, think about the environment.
The @[ works well, but it when you have a return and continue on the next line, it creates a box for each line. It there a way to have it just create a box around the whole paragraph.
Doug
