Hello Folks,
I hope you are doing well as you read this email.
I have attached a dummy of a bottle I´m working on now.
The image shows rounds of 7,5 mm that I´m trying to create, so far unsuccessfully.
I have tried all the tricks I know. Even tried to create a surface round to somehow try to solidify it and cut the remaining solid inside....it did not work.
if you could take a look at it, I would appreciate.
what are transitions? when referred to in terms of rounds. it seems this is what is causing the error.
thanks, best regards from Caracas
Al.
