Hatch of a section not completely shown
GF_10659403
I am using Creo Parametric Release 11.0 and Datecode11.0.3.0; in a single view, the hatch of a section is not completely shown. In a different view with the same charatheristics, the hatch is correctly shown.
Finally I found the solution... With the option in the image attached set on "No" the hatch is now completely shown.
5 REPLIES 5
Hi @GF_10659403
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Creo looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Hi Catalina, I forgot the image...
A you can see, the hatch on section B-B is complete, but something doesn't work on section A-A.
Dale_Rosema
(To:GF_10659403)
Try moving the bottom portion of the section line .01 to the right or the left. Sometimes when going through the center of cylinders Creo has an issue due to the splitting of the cylinder in half.
Thanks Dale, but nothing changed flipping back and forth on the other side.
