I am making threads for a part, and they are starting and ending at the middle of the part. How do i get the threads to be continuous?
D
Danielle,
I hope i have understood your query correctly. Yes, you can change the end of threads by changing the trajectory for the sweep profile. Observe the end tip of the trajectory profile and sweep also.The attached the images are self explainatory. Let me know if there is any misunderstanding of the query.
Danielle,
