Help - How to orient single dimensions ( 2d drafting)
JGuest
Does anyone know how to enter the options for ; parallel, horizontal, vertical ect for single dimensions when working in annotation.
I enter the number 1 for parallel or 3 for vertical in the bottom screen user input and then start the dimension and I don't get the result, just always get an aligned dimension.
Jason
1 REPLY 1
JGuest
(To:JGuest)
I found out just right click the mouse for the options to select your alignment after clicking on the command.
Jason
