I need some help with CREO 2.0. I loaded it in and started to follow the directions to load the bike into Creo. I can not seem to make the bike appear. Any sugestions
Updating your graphics driver should fix this for you. If that doesn’t help, please try the suggested config.pro options in this document: http://apps.ptc.com/schools/references/support_creo2_graphics.pdf
Adam
Academic Technical Support:
