Help on Modelling Fish Scale Array
AH_10155331
I am trying to model a fish scale array pattern as a film like structure. but unfortunately i cant able to create the overlapping surfaces. I figured that I need  some degree of tilt between the individual scales and the base.Attached pictures of what iam getting and what I need.  Help me to get the desired output.
create an assembly, add single fish scale into it and pattern it.
Martin Hanák
4 REPLIES 4
Martin Hanák
Thank you for your help, I'll try it
tbraxton
22-Sapphire I
(To:AH_10155331)
If you have access to the additive manufacturing extension it is possible to create a custom lattice that will greatly simplify modeling this type of pattern. I would do some investigation on that method if you have the extension available.
Involute Development, LLC
Consulting Engineers
Thank you for your help, I am using student version , so i think i can't able to avail that extension
