Hi all,
i have raised this issue before but i keep trying in the hope someone may have a solution. The problem is with hidden lines in my drawing, i know this may seem strange, but even though this is hidden detail i want certain lines to appear as solid geometry. Is there a way of changing the line style of some hidden lines but not all in the drawing, so instead of being dashed they are solid (continuous)?
Regards
John
Hi Kevin,
thanks for the reply, my only problem with that is would like my views to remain parametric, i use this model & drawing all the time. I guess i will stay with the method i have, it has served me for years. I wrap the text around the cylinder & mirror it about itself, then create 2 layers & put one on each, then its just a matter of turning the layers on & off as required.
Regards
John
perhaps i should have added that what i am trying to do is essentially look through the model as if i were looking into a cavity rather than a solid model, i know this will not make sense to some, (maybe all), but it is something that would greatly help me with my work.
Regards
John
Hi John,
Without understanding exactly what you're trying to do, would a local (partial) section be a possible solution?
Otherwise, I find the most robust way to create cosmetic detail in the drawing is to create a sketch in the model, then use layers to show it only in the appropriate view. This way you can reference the relevant geometry, and the sketch doesn't fall over or forget options if you alter drawing views.
HTH,
Jonathan
right click line style
Assuming you are using WF5 on the layout tab select Edge Display, select wireframe for the edge display type, and select the lines you want to change. If you're using an ealier version Edge Display is probably somewhere under the View menu.
Thank you for the replies,
ok, reading back my post i realize that i have mislead you, what you have all described works for geometry, i was already aware of this. The hidden detail whose style i want to change belongs to sketched text wrapped around a cylinder, it needs to read the right way in one particular view but appear mirrored (back to front) in another. I create 2 views, 1 front & 1 rear, the front view shows the text reading right & the rear view shows the text mirrored, but its hidden, this is what i want to change.You do not appear to be able to change the style by the described method. Like i said before, some might find this diificult to understand or question why, but its how i get the job done.
Regards
John
The only way I'm finding to do what you want is to convert the view to draft entities or a draft group.
Hi Kevin,
Regards
John
Hi all,
for anyone that is interested, i figured out a solution to this problem. There is a config option under drawing options, hlr_for_datum_curves, if set to no, datum curves are not treated as hidden lines anymore, they keep the same line style & colour regardless of being hidden detail.
Regards
John
