Hi community, is there a chance to hide the lines, espacially the outer ones, of a table on a drawing? Backound: On our drawings we mostly have a bunch of annotatitions.
Since the formatting options within a note are pretty small, I´d like use a table to show annotations. Unfortunatly i do not know how to hide outer frame lines of the table.
Attachment: 29-04-2015 09-00-03.png
Regards from Berlin, Danny
This keeps coming up...
If you have the privilege, please vote :Allow blanking Table outline border
Danny,
unfortunatelly, outer frame lines of the table cannot be hidden.
When you create table containing one cell, then you can set its height/width to 0.01 mm. This causes, that outer border is "invisible".
Martin Hanak
