Hiding Border of single Table & showing the text
ptc-1866234
Dear Support, Kindly help me to hide the border of single table cell in Drawing & want to show the note only. Regards Pramit
3 REPLIES 3
Select (Highlight) table, then Table>Line Display...>Blank, then select table line(s) to blank. Regards-
"blank" is only for cell borders. i can not hide table borders in wf 5.0
I have not been able to do this. However, if you can create a line style that does not print, you could change the linestyle. This affects the entire table.
When I needed a parameter driven cell, I made the table the size of the format so it became the very outside border. All the internal lines were blanked. There was a cell in the location I needed the parameter to show up in.
The only issue I had with this is that it was easy to accidentally grab the table and drag it. You will want to make this either a read only layer or turn it off while working on the drawing.
This would be a good idea to make a table border blank and/or assign the table border a not-plot option font.
