Hole Tool vs Cut
fred_renner
Hole Tool vs Cut
Dear Users,
When using the hole tool, is there a way to make multiple holes in the one feature? I like the hole tool's ability to make countersinks, counterbores etc. automatically, but there doesn't seem to be much convenience to it if you can't make multiple holes in one feature. I would like to be able to make groups of holes related to each other for the purpose of a mating part in an assembly.
Fred
Fred Renner
Designer/Drafter
Applied Engineering, Inc.
3300 Fiechtner Drive
Fargo, ND 58102
8 REPLIES 8
That sounds like a case for patterning.
I was hoping for a way to do it without any additional features (like patterns).
Fred
Fred Renner
Designer/Drafter
Fargo, ND 58102
Are they holes for assembly or holes in an assembly? Patterning seems to
be the way to go and with WF3.0 and above is easy.
Richard A. Black
Lead Engineer
Eaton Corporation
16900 Aberdeen Road
Laurinburg, NC. 28353
Which is why a lot of people use a cut to create a quick set of holes. It would be nice to be able to create a series of holes (maybe like sets when creating rounds?) in one feature.
Yes, Jim Tierney's response is what I'm wondering about.
Fred Renner
I believe I heard that WF5 has the ability to pattern points in the
sketcher. Potentially you can create
one hole feature on those points and end up with multiple holes.
Doug Pogatetz
Northrop Grumman Corporation
Hi Fred,
In my early days with ProE (starting at R14) I considered Hole a feature poor subset of Cut for the lack of control and dimensioning references. However we do not do much requiring tapped holes so the extras you could do with hole were of little benefit. Over the years I have moved to using whichever of Hole or Cut seems more applicable. Multiple clearance holes I mostly use Cut and feature rich holes I mostly use Hole.
With this in mind I suggest for machine assembly that you consider Top Down Design and the use of Skeletons. I would imagine I would have axes in the skeleton that are used to align all the mating holes and to which the bolts/screws are assembled (means if any parts are suppressed or rolled back everything else stays in place). I would use Publish Geom in the Skeleton to group the alignment features and Copy Geom in the parts to import that alignment and then make holes on these copied axes. Making the holes then becomes very easy as you are picking axes as your reference for making collinear holes rather than having to dimension each one from two faces. The added bonus is that the Skeleton controls the fastening positions and everything always lines up.
Hope this helps.
Regards, Brent Drysdale
Mechanical Designer
Tait Electronics Ltd (www.taitworld.com)
New Zealand
Ph. +64 3 358 1093
Fred Renner wroteSmiley Tongue { margin: 0; }Dear Users,
Fred
Fred Renner
Designer/Drafter
Fargo, ND 58102
Tel: 701-281-1884
Fax: 701-281-1322
Email: -
Web: ae-solutions.com
I think what WF5 adds is the ability to take a sketched datum point
feature and use it to define a pattern, placing a hole at each point in
the sketch.
Doug Schaefer
LinkedIn
