I have supplier Drawing in AutoCAD and I want to take it in Creo Title block. So I do Import and select Autocad file in drawing. But There is issue with texts when importing to CREO.
Text in Autocad drawing & in Creo(imported drg) are not matching. So, What to do for that? Is there any option to import texts as seperate entities? now due to that All texts are not showing proper in drawing(overlapping)
I want to put supplier drawing in My format.
I guess that AutoCAD drawing uses text font non-compatible with Creo. That's all.
Martin Hanak
But is there and provision for Import any texts as Draft entity?
I do not think that you can convert text to draft entities during importing AutoCAD drawing into Creo. You have to make the conversion before importing in AutoCAD. If you do not have AutoCAD available, download and install its free alternative - DraftSight.
Martin Hanak
