How I can add sheetmetal thickness in to BOM?
akshay_deshmukh
@akshay_deshmukh
As in first reply you can call SMT Thickness in repart region table by adding  &asm.mbr.SMT_THICKNESS (Report parameter > asm > mbr > user defined > Type SMT_THICKNESS)
6 REPLIES 6
@akshay_deshmukh
Do you want this to be added in Repeat Region? If yes, you can add &asm.mbr.SMT_THICKNESS.
Or Is it for "Bill of material" from Tools > Bill of material .  In this case you need to customize BOM format file.
Thanks for reply.
I want to add it in my BOM so that I can see the thickness of every
component in that.
@akshay_deshmukh
BOM???
How are you creating BOM?
I am creating BOM using repeat region adding Sr. No., Part Name, Qty.,
Material etc.
Tell me how can I add column having thickness into my bill of material.
@akshay_deshmukh
Thanks.
Its working.
