How can I add an additional leader to a radius dimension in a PTC Creo 3.0 drawing?
shamrick
I want to add an additional leader to my drawing on the outside radius dimension to call out the internal radius with it.
How can I add the additional leader?
Kevin
(To:shamrick)
You can't add an addition leader to a dimension. Standard practice is to call it out using 3X for example. If you you want to have multiple leaders you would use a note.
7 REPLIES 7
select your leader, RMB create witness line
unless I'm selecting the leader wrong, this is what I get with I RMB:
No create Witness line
this is what I got
With that being said, you may have to select near the arrow, if a little box/circle appears, drag that around.
it means it was already created but just needs some lovin' to show up.
ron
ps - I am playing on CP2 if that makes a difference
Kevin
(To:shamrick)
shamrick
(To:Kevin)
I agree Kevin....sometimes standard practice is practical practice to some others.
So you wanted to do this:
and not this:
Anantj18
(To:shamrick)
This would be the best way to do it:
https://www.youtube.com/watch?v=kV1zZ9FPfJ8
tldr: Create a multiple leader note and inside the note type '&' followed by the dimension parameter, for eg: &d56
Using this video you can add multi leader dimensions and multi leader notes in Creo Parametric drawing.
