Unless some new functionality has been added, this is not possible. Creo stores TTF in a directory and not in models.
If you are using the TTF to create solid geometry in a model, then you can try exporting it is a neutral file or STEP to supply to your vendor. If they need to work with the Creo file, then they would need to install the font in their Creo environment.
Just send the vendor the font file from the directory. Manual process but it will get the font to the vendor.
