I've recently received several Creo models and drawings. In a few drawings I've noticed that while some dimensions are displayed as 5.00 they are actually 5.001325334....
Is there anyway I can quickly find such dimensions without having to manually interrogate each one? I can then fix these dimensions in the model.
Hello rhudd
try following in drawing space.
1. Active Annotate bar - set filter to dimmension (right bottom corner)
2. Select all dimmensions in your drawing (with mouse)
3. Press RMB - select properties - set decimal places to 30
4. Find "bad" dimmensions
Hope it can help
Hello rhudd
Hope it can help
Thanks for the suggestion, this is a nice approach that works well.
