I am running CREO 3.0 M090.
I have created a Repeat Region for the BOM on our Drawings.
I would like to add a column in the BOM that will display the Session ID for each part in my BOM.
I have looked at all of the RPT Parameters but cannot find anything that will work.
Anyone have any ideas?
I do not believe that is possible.
I have gone at it from the other direction before. Copy and paste the text from the attached file into a note on the drawing.
Thanks for the info.
