Hello all
I´m a big fan of using Snapshots with contraints values to describe sequences of mechanical designs.....but I hope you will help me how update the Snapshot Contraints values in an easier way.
This is the way I do it:
1) Create one snapshot with all the contraints needed with the correct values for that sequence-step.
2) Copy above snapshot and correct the contraints values for this sequence-step
3) Etc
The problem I find is that it´s very difficult to update, for example when I need to add a constraint I must click on every snapshot and update them, also it´s difficult to compare the snapshots to debug when something goes wrong.
The attached pdf shows a simplified ASM with some notes to explain what I mean 🙂
BR Jan Olsson
Please specify which version of the program you are using.
