How can i open Creo file in CorelDRAW X6?
fdefilippi
I have made .prt file in Inventor 2016. Then i import the same file in CorelDRAW X6 software. It's shown "Unrecoverable Error". Please give suggestion.
7 REPLIES 7
You can fool the system if the replaced part is part for part or assembly for assembly and only if the names are the same (working in a temp folder).
Replacing the model from a part to an assembly will require creation of new views.
thanks.  would be a nice feature to have like most of systems I've used
I hear you.  I've been caught behind that 8-ball a few times doing sheetmetal chassis that used pierce and extrude features.  Then a "simple change"... "please use captive hardware".  Same story; part became an assembly.  Drawings were fully detailed.
Simplicity says to just add the new model and make a duplicate view next to your current view.  Copy and re-associate what you can.  If you are lucky, you can move the associative dimensions form one view to another (not holding breath for that one).
Older systems use to use a "viewport" type analogy where the whatever part exists shows in the viewport.  Somehow that changed to model dependent viewports.
There may still be better methods out there and I am all ears to hear them.
So with that statement, I have no choice to but to make a new drawing.  As such that is the last thing a company or employer wants to hear from engineering on a simple design change requires a lot of CAD work
mender
6-Contributor
(To:fdefilippi)
Look to Creo 4 for an enhancement in this area.  For now, this particular one you'll need to re-detail, sorry.  Also note that 'fooling' the system into unrelated model replacements is a very bad technique that can result in crashes, corruptions, and unpredictable behavior, it is highly not-recommended.
TomD.inPDX
(To:mender)
Fooling the system is a hail Mary when you miss a step in a complex process or the system fails you.
Normally, it is the same part with maybe a simple revision change that requires this method.
For completely unrelated models, definitely not recommended to fool the system.
Glad to see PTC has finally seen this as an issue.
mender
6-Contributor
(To:TomD.inPDX)
Yes, I'd been mentioning it for many years, but there's always a lot of project proposals to fit into never-enough development time.  But when this comes up in the future when you're on Creo 4, you should find your job considerably easier.
