Hello dear members,
Can someone help: How to know if any joint operation is performed on Framework profile part or not? Model tree doesn't show that information. Thanks
Hi @umg ,
you can either see it when the joints dialog is open via the displayed symbols or you can open the verify project dialog that shows all beams and their joints.
Hope this helps.
Hi @umg ,
Hope this helps.
