How do I close the hole left by a surface trim?
ptc-3143527
Hello, I have used a sweep-surface trim to trim a quilt that was previously closed - now I have the geometry I want but there is a hole in the model where the cut went thru. Is there a way to retain this surface as the cut goes thru? What feature will close this hole I have? I need it close so I can solidify it later. Thanks, Matt
0 REPLIES 0
