I am trying to create a shape like thishttp://www.google.com/imgres?sa=X&biw=1280&bih=890&tbm=isch&tbnid=gUrw4Oqrfr_kvM:&imgrefurl=http://commons.wikimedia.org/wiki/File:Ellipsoid_Labelled.png&docid=4VgrjD0GQ321rM&imgurl=http://upload.wikimedia.org/wikipedia/commons/a/ab/Ellipsoid_Labelled.png&w=2170&h=1237&ei=FX0SUt3hKoSGyAHQtIBI&zoom=1...
Kind of a revolved ellipse but I want the Ry value of the ellipse to be different on the front and right planes. If I construct it from boundary blends I'll get a pinched surface at the poles. Is there a way to achieve this sort of thing with variable section sweeps? I really need a variable revolve feature please 😉
Any suggestions appreciated, thanks!
I should clarify that the central profile should be an ellipse not a circle. More like this actuallyhttp://img.tfd.com/ggse/e6/gsed_0001_0030_0_img9466.png
This can also be done with a few construction curves and two variable section sweeps sketched with conics.
Surface quality may be a little better than a trimmed back boundary blend.
Mesh is definitely better than a 3 sided quilt with singularity
The technique was documented and demonstrated here:
http://www.mcadcentral.com/creo-modeling/17699-nose-c-ne-help.html
